Ga door naar hoofdinhoud
De Xiaomi Poco X3 Pro is een instapmodel smartphone van Xiaomi, uitgebracht in maart 2021. Het toestel is uitgerust met een 6,67" IPS LCD-scherm, een 48 MP hoofdcamera en draait op de Qualcomm Snapdragon 860.
Phone is Dead (POCO X3 Pro)
๐Œ๐ฒ ๐๐จ๐œ๐จ ๐—๐Ÿ‘ ๐๐ซ๐จ ๐ฐ๐š๐ฌ ๐ฐ๐จ๐ซ๐ค๐ข๐ง๐  ๐Ÿ๐ข๐ง๐ž. ๐Ž๐ง๐ž ๐๐š๐ฒ, ๐ˆ ๐ฉ๐ฎ๐ญ ๐ข๐ญ ๐จ๐ง ๐œ๐ก๐š๐ซ๐ ๐ข๐ง๐ , ๐›๐ฎ๐ญ ๐š๐Ÿ๐ญ๐ž๐ซ ๐ญ๐ก๐š๐ญ, ๐ข๐ญ ๐ง๐ž๐ฏ๐ž๐ซ ๐ญ๐ฎ๐ซ๐ง๐ž๐ ๐จ๐ง ๐š๐ ๐š๐ข๐ง.
I tried different chargers and pressed the power button many times, but nothing happened. The screen is completely blackโ€”no light, no vibration, no sign of life.
I took it to a few mobile repair experts. They tried to revive it by revoking the processor maybe, but it didnโ€™t work. One expert said the memory chip might be the problem and could need repair.
The most important thing is, I have very valuable data in that phoneโ€”photos, files, contacts, and work documents. I donโ€™t have any backup, and I really need this data.
Is dit een goede vraag?
Score 1
1 Opmerking:
เฆฏเฆ–เฆจ เฆ†เฆฎเฆฟ เฆซเง‹เฆจเฆŸเฆฟ เฆšเฆพเฆฐเงเฆœ เฆฆเฆฟเฆšเงเฆ›เฆฟเฆฒเฆพเฆฎ เฆคเฆ–เฆจ เฆซเง‹เฆจเฆŸเฆพ เฆเฆ•เฆŸเง เฆธเฆ• เฆฆเง‡เฆฏเฆผ เฆเฆฌเฆ‚ เฆซเง‹เฆจเฆŸเฆฟ เฆ“เฆฐ เฆนเฆพเฆค เฆฅเง‡เฆ•เง‡ เฆชเฆกเฆผเง‡ เฆ—เฆฟเฆฏเฆผเง‡ เฆกเง‡เฆก เฆนเฆฏเฆผเง‡ เฆฏเฆพเฆฏเฆผ
door
Voeg een opmerking toe
1 Antwoord
Filteren op:
@albertmarshall that is the age old problem with not having backups. There is no way you get the data of your phone unless you get the phone to start up. Transplanting or replacing the memory IC will not recover your data.
You need to determine where the error is. Something like this "revoking the processor maybe" does not tell us much since we do not know what they did. Nor do we know what they have checked. Commonly a no power situation is related to either the charging board, a shorted battery or a torn flex that comes from the daughter board to the main circuit board. Check/replace those. Then check the voltage on your battery connector with the phone plugged in and without.
To replace the battery, use this guide Poco X3 Pro Vervanging van de batterij For the rest use this video Let us know what you find out.
Was dit antwoord nuttig?
Voeg je antwoord toe
Albert Marshall zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 30
Altijd: 612
