Ga door naar hoofdinhoud
The first model of iPhone, Model A1203 with 4, 8, or 16 GB capacity and an aluminum back. Repair requires a significant amount of prying, and may require some soldering. This page aims to help users troubleshoot, fix, and seek help for the iPhone 2G.
20 Vragen Bekijk alle
Is there a software to bypass the ring silent control?
I droped my iPhone & my silent mode switch is broken it is blocked on silent mode
Is dit een goede vraag?
Score 2
Voeg een opmerking toe
4 Antwoorden
Gekozen oplossing
Here's an application that will bypass your silent control: http://iPhonepackers.info/AutoSilent.htm
Was dit antwoord nuttig?
Score 5
1 Opmerking:
+1 Cool! That's useful.
door
If such software exists, I can guarantee that Apple does not sanction it. You may be able to find a solution if you jailbreak your phone.
Score 2
sounds like a good idea but I'm unable to test it right now I'm facing problem with cydia it is quiting when ever i want to launch it, it looks like i have to re install it first thank u any way for the tip
2 opmerkingen:
cydia?
door
Cydia is the jailbroken app catalog.
I think that Cydia's quitting is documented right now- I believe they are working on a fix with the repos.
door
i too had this problem a while ago with my iphone 4. after spending days around forums and all i almost gave up. but then accidently i came across the ringer/silent sbsettings toggle. nd it definitely saved me a %@*@ lot of money.
solution is if ur iphone is jailbroken, go to cydia.if not, jailbreak and install cydia.install sbsettings thru cydia. and after u have installed sbsettings, search for ringer/silent sbsettings toggle. it wil work miracle :)
Voeg je antwoord toe
Redha zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 4
Altijd: 7,553
