Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
Wat zit er in een chip? Hoe werkt het? Computerchips worden ook wel geĂ¯ntegreerde schakelingen, monolithische geĂ¯ntegreerde schakelingen, IC's, chips of microchips genoemd.
Help Identifying a chip
Hello, I have a Vizio S2920w Soundbar which has a blown chip on it. I was wondering if anyone here could help identify it. Its marked 9F 2 and has U7 written on the board beside it. All help would be appreciated!
Afbeelding
Is dit een goede vraag?
Score 1
3 opmerkingen:
Hi, I’m having the same problem. Were you able to identify the component? That would be a great help.
door
@albert45304 from whatever is left to identify the component, this could very well be a Voltage regulator. Check on here You can relatively easy identify if it is a V Reg if one of the middle pins looks a bit odd. Again datasheet will show what I mean by that. You can also desolder the component and check the bottom side for what the center pins look like.
door
@oldturkey03 Thanks, that was really helpful. It’s definitely one of these.
door
Voeg een opmerking toe
1 Antwoord
Filteren op:
It looks like you have some other material to remove and underneath that there are the actual identifying markings.
Was dit antwoord nuttig?
1 Opmerking:
Unfortunately I cannot remove that as thats the actual plastic itself which has burnt and turned white.
door
Voeg je antwoord toe
TechVid zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 18
Altijd: 251
