Ga door naar hoofdinhoud
De smalle versie van de klassieke Xbox 360 met een harde schijf van 250GB en ingebouwde wifi. Reparatie vereist nauwkeurig wrikken en speciaal gereedschap.
How to repair GPU
GPU killed itself about 2 years ago and I've found no one willing to repair/replace it or tutorials online. If it really is impossible to fix, how should I go forward? This thing has too much precious data to lose
Is dit een goede vraag?
2 opmerkingen
@turkeylegs lets see if our game console Guru @dan0 has any ideas on this one.
door
Sorry for the late response again, my friend.
door
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
@turkeylegs on your 360 S the GPU is part of the CPU. It is not impossible but will require to have the tools to do a total reball. That means you would at minimum need the stencils, a BGA reflow machine and a new processor. That is where you run into trouble. Those do no longer exist. That means you would need to use an old/used processor. Nobody can/will work with processors that nobody knows anything about. Think about it, you may be buying somebody else's problematic chip.
Was dit antwoord nuttig?
Score 1
1 Opmerking:
I totally agree! So, the best thing to do is to buy a known working motherboard in this case. It IS more expensive… but will save you a lot of time as it is way easier!
door
Voeg je antwoord toe
Turkeylegs zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 5
Altijd: 177
