Ga door naar hoofdinhoud
Dit apparaat, aangekondigd op 9 september 2014, is Apples eerste stap in de wereld van draagbare technologie. De reparatiehandleidingen van iFixit zijn van toepassing op de Apple Watch (staal) en Apple Watch Sport (aluminium).
Apple Logo Appears Only Once When Plugged In
Hello everyone!
First of all, I do not know which version of Apple Watch this is. Someone gave it to me, but did not tell me which model it is. I believe it is an Apple Watch SE, but I am honestly not sure.
Well, the Watch simply does not turn on. When I connect it to the MagSafe Charger, I see the Apple Logo for about half a second, and then it disappears. If I play with the buttons a little bit, sometimes I can get it to turn back on... but the Watch itself I cannot get to boot. I would think this is either and issue with the battery or the button itself. Since I have little to no experience with the Apple Watch, I figured I would like to hear from you guys before I get inside. What do you guys think this issue is?
Is dit een goede vraag?
Score 1
5 opmerkingen:
Hi @jadonlyon
Check on the back of the watch as all the information regarding model etc should be printed on there
door
42mm case • 7000 series aluminum • ion-x glass • composite back • serial fh7r6blzg9j
door
@jayeff - I am not sure if this helps
door
@jadonlyon
7000 series indicates that it is the original Apple watch i.e. the very 1st one released. Not to be confused with an Apple Series 1 watch which came next.
ifixit still has some parts for it but not many.
door
@jayeff - Oh, that's old....
door
Voeg een opmerking toe
2 Antwoorden
@jadonlyon
Yeah.
Given its age most likely it is a battery problem if it has never been replaced and if it hasn't been charged for a long while.
Update (12/21/24)
@jadonlyon
I've changed the device you selected for your question to the correct one for the model.
Click on the Apple watch - original icon (to the right of your question) to see the ifixit repair guide.
Cheers
Was dit antwoord nuttig?
2 opmerkingen:
@jayeff - Then I will check that first. Thank you!
door
@jayeff - Thank you so much!
door
Here’s the guide to replace the battery Apple Watch Vervanging van de batterij iFixit still has replacement batteries for this series. Make sure you get the kit as you do need a few other parts s well.
1 Opmerking:
@danj - Thanks for this info
door
Voeg je antwoord toe
Jadon Lyon zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 18
Altijd: 361
