Ga door naar hoofdinhoud
De Xbox 360 is de tweede spelcomputer die Microsoft maakte en werd uitgebracht op 22 november 2005.
How to fix "unrecognized disk"
this just happened to me today. i opened it and cleaned it out and it still wont work. every time i put a disk in, it says unrecognized disk. i want to fix it but i already fixed it for red rings so I don't want to put anymore money into it. besides ps3 (even ps2) is better than xbox!
Is dit een goede vraag?
Score 2
1 Opmerking
when you say cleaned it out, what did you clean out?
door
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Zane, the first thing I would suggest is that you clean the laser. you can purchase a DVD cleaning kit at most department stored. Should you have no luck finding one, you ill have to disassemble your optical drive. Here is how to get it out, and on here you can see how to disassemble the individual drive. Make sure you select the right optical drive, there are a few different ones. Once cleaned you can try it and see what happens. If the cleaning did not help, you can try a Pot adjustment. Great instructions are downloadable from here. Be sensible with the adjustment. If you are not up to that, you can of course also replace the laser assemble, or the whole drive. Just remember that "Xbox 360 is designed so that the DVD drive works only with the particular game console it is installed in". So you will have to reflash it or keep your original PCB and replace your drive with the same model, and switch the PCB over. Hope this helps, good luck
Was dit antwoord nuttig?
Score 1
1 Opmerking:
I brought a cleaning DVD for my.Xbox and it doesn't read and my black ops 3 doesn't read ether
door
&&^& you @%^$$@$# all of you
1 Opmerking:
Your &&^&^$^ shyts broke you got it good go cry and die or buy my product u son of a ##&&%
door
Voeg je antwoord toe
Zane zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 20
Altijd: 15,079
