Ga door naar hoofdinhoud
In August 2000, the ninth-generation Corolla was introduced in Japan, with edgier styling and more technology to bring the nameplate into the 21st century.
How to put off the maintenance light
I have the method of removing one of the battery terminal and replaced after few seconds but it does not work
Is dit een goede vraag?
1 Opmerking:
Sorry you don’t have enough information about the problem.
Just turning light off is not a fix if cause is not known.
door
Voeg een opmerking toe
1 Antwoord
Your maintenance light will illuminate when it's time to schedule a service, so it's important to stay up-to-date on your oil changes and tire rotations. But if you take care of your routine maintenance at home, you might need to reset the light manually.
  • Place your key in the ignition and turn to the "on" position, but do not start the vehicle.
  • Press and hold the trip reset button until "Trip A" pops on the screen.
  • Turn your key back to the "off" position.
  • Press the button to reset the trip and turn the key back to the "on" position.
  • If the miles section of the odometer suddenly flashes zero, you've successfully reset the maintenance light.
What if your attempt didn't work? Try again. Sometimes it takes a few tries to get the timing right.
Was dit antwoord nuttig?
Voeg je antwoord toe
Olasunkanmi Saheed Fadipe zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 12
Altijd: 32
