Need help with Capacitor Power IC
Hello, I am looking for an SMD capacitor value. I already have a schematic, but the value is not available in this package 0402. Can you help me?
Afbeelding
Hallo, ich suche einen SMD-Kondensatorwert. Ich habe bereits ein Schema, aber den Wert gibt es nicht in dieser Bauform. Könnt ihr mir helfen?
Is dit een goede vraag?
4 opmerkingen:
Hi!
Is this were you are looking for?
https://www.reddit.com/r/electronic_circ...
door Deel
No, I have a Nintendo switch OLED
door Deel
@mwg16647 does it say 200µF on your image? I've not seen any 200µF SMD caps. Not saying they don't exist but I would double check the source and the value. You do know that with capacitors you can go with a higher capacitance, so try to see if you can find that at mouser.com or digikey.com
door Deel
Yes, that's why I'm writing here in the forum, hoping someone might recognize the capacitor. Unfortunately, I bought the XZZ schematic VIP, but the values cannot be seen there. 40€ down the drain.
door Deel
Voeg een opmerking toe
