Ga door naar hoofdinhoud
Informatie over reparatie en demontage voor de Samsung Galaxy S21 5G Android-smartphone, inclusief model SM-G991U.
WI-FI constantly turning itself off
Okay so I got this phone second hand, it is the Galaxy S21 FE 5g, the wifi constantly turns itself off after about 10-15 minutes on the new ui 6 update, i’ve been through all settings involving samsungs smart connect, and factory reset multiple times. no cracks or outside damage. the bluetooth is fine so I know it’s wifi specific and happens on every network. it’s not my main phone but I would like to invest a little into fixing it, I just don’t know what i’d need to replace or if samsung is still as repairable as it used to be, i’ve had an iphone as my main for quite a while now
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
Check for any battery saver settings being turned on... it might be that it's turning off the wifi to conserve power.
Was dit antwoord nuttig?
Score 1
4 opmerkingen:
Did you figure it out ? Mine is doing the same
door
I changed the power saving to high performance and it fixed the same issue I was having with the wifi turning off
door
I'm having the same issue
door
Same issue, and non of the solutions work.
door
Samsung has tech support for that. Not the sharpest knife in the world, but it is free and they can log onto your phone and look at it.
That is your best option.
Voeg je antwoord toe
dominick giovannelli zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 46
Altijd: 1,533
