2004 Jeep GCL 4.0 v6 turning over but not starting.
2004 jeep GCL will turn over but willnot start. Alternator, battery, fuses and fuel pump are all good, spark plugs have been changed and even tried spraying gas directly, no spark. Cam and crankshaft position modules also been replaced. It also had a recall occupant restraint module replaced by dealership.Jeep dealer says nothing showed up on the Diagnostic when replacing ORM, but need to bring it in for a 2nd one? This sound shady to be honest since they can't find the first Diagnostic report, not to mention that I would have to tow it cause it will not start. What if anything should I replace or check next? I can give more detail if needed, also have video and pics if needed. I'm seriously desperately in need of some solution, the jeep mechanic is not being honest or doesn't know what he is doin...
Is dit een goede vraag?
1 Opmerking
I been having issues with this car since my gf let someone barrow it, idk what the dude did but the cooling fan (I think that’s what it’s called) you know, the fan in front of the generator stopped working. Car eventually began to over heat frequently, I kept using just water for a temporary fix. One day I guess I pushed it too hard and now the car barely stays on. I have to press on the pedal to turn it on or else it won’t, the battery is starting to die on me and has happened already 3 times. I believe it’s probably the alternator because ever since that day I tried to drive it from Tampa to Saint Petersburg it just completely killed it. Any thoughts? Oil is fine, but need a replacement soon, has gas, engine smokes after forcing it to move a bit, need new break pads, cooling fluid need to restock, steering fluid is fine, break fluid is fine…just need to pretty much seek advice on what could it be before I take it in. I’d like to see if I can fix the issue by myself
door Marcos Yadier Gonzalez Cotto
