Ga door naar hoofdinhoud
Idylis 70-pint dehumidifier (large size area over 3000 sq ft) featuring direct drain option for continuous use.
1 Vragen Bekijk alle
How do I replace this button?
Basically, I've had this thing for years and years, it's sort of a little ragged, but it still seems to take water out of the air, honestly it got left running during some dusty work and it's never been the same since, the lights for the fan speed have also given up the ghost. but that's not what matters right now.
What matters is the power button is completely obliterated and I'm wondering how difficult it would be to replace it, I'm coveting hack-y solutions because they sure don't give these things away, trashing this thing and purchasing a replacement is eating a big loss
Technically sticking a small object into the hole and poking at the raw button on the PCB kinda-sorta-sometimes works, but it's getting worse if anything, this button's days are numbered.
Also a concern: if I replace this button, how do I seal it from moisture? I feel like it's not a great idea to just drop a different button in and be in the same "Sticking a pencil into the hole" boat.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Search on ebay because it looks like someone is selling the same top panel containing that set of ‘soft’ buttons.
https://www.ebay.com/itm/124087477604?mk...
Was dit antwoord nuttig?
Voeg je antwoord toe
Aeri zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 48
