No water while spinning
When spinning on rinse cycle the Water used to come on periodically for 3 or 4 seconds then shut off. My machine is not doing this anymore, otherwise it work fine
Is dit een goede vraag?
If the water is getting in during other parts of the cycle, would indicate water valve is ok. If equipped , try selecting other cycle modes.. Hot vs Cold , Delicate vs Normal , try to make sure you are getting both Hot and Cold water in. If only one or the other temperature gets in , it is most likely the water valve. The other suspect if both temperatures work, would be the timer, not providing the electronic connections properly. This just general info without knowing your model Make / Model etc.. Good Luck.
Was dit antwoord nuttig?
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 11
Altijd: 241
Hi @scott10453203
What is the model number of the washer?
door jayeff Deel
