Ga door naar hoofdinhoud
Repair guides and disassembly information for the MacBook Pro 16'' released in November of 2019. Model A2141, EMC 3347.
Replace the thermal grease/paste
There is no guide yet on how to replace the thermal grease/paste.
These Macbooks are now around 4-5 years so it's not a bad idea to replace the thermal paste.
They're not obsolute so there will still be users who can benefit from a guide.
Update (04/01/24)
Update:
So I was able to open the MacBook and disassemble the motherboard with the video.
Since I'm comfortable around electronics (this isn't my first time opening up a MacBook, laptop, or even a smartphone), I did choose to replace the thermal paste on the cpu and gpu.
And honestly, after four years of service... Kind of disappointed about the original paste. Dan said that paste will last longer now due to improvements, but the original paste was crumbly as hell. Furthermore I noticed small blank spots on the cpu and it's heatsink, so not very good spread. The gpu did have a good spread. They definitely were generous with the paste on the gpu, because its surroundings were covered with paste too.
Cleaning wasn't difficult, as I said the paste was in a very crumbly state.
After cleaning I gave the copper plates of the heatsink and the cpu and gpu some time to evaporate the alcohol.
I used Noctua NT-H2 and used the "X" to spread the paste on both cpu and gpu.
The only annoying experience was to place back the motherboard in the case. I needed multiple attempts because there was always some small connector/ribbon cable underneath the motherboard. Ugh! After playing like an octopus for a while, I was able to place the motherboard back and with all connectors/ribbon cables out on top of it.
It's do-able but only for people who have a steady hand and... most of all... lots and lots of patience. Take your time. Take some breaks if you get tired or frustrated because the moment that you attempt to work a bit faster or anything like that... something will go wrong. I 100% guarantee that.
I made only one mistake. The connector cable from the left fan is incredibely fragile due to its L-shape (that's what I think). In trying to get the L-shape cable from underneath the board to the top on the board, I got a small tear in the ribbon cable. This fan no longer works. We learn from our mistakes. Should've taped the connector on top of the fan, I wouldn't had an issue to "fish" for the cable since it can't get trapped underneath the board that way. Already ordered a replacement fan.
The temperatures are amazing though. In idle I went from 60-63° to 46-51°. The one remaining fan is also a lot quieter. I'm not going to claim this huge difference to the new paste though. There was so much built up dust in the MacBook... I was genuinely surprised that the MacBook didn't have much higher temps in idle. Both fans were completly covered up in thick dust, and the outlets on both fans same thing. How it managed to get some kind of airflow through those thick dust is a mystery to me.
Anyway, I am very happy with the result. Yes, I did damage one fan connector, but one can only learn with making mishaps.
Is dit een goede vraag?
Score 2
1 Opmerking
Ah! The lack of wetness issue. The silicon oil is just a carrier for the solids which is doing the job! So yes it is dry, but that’s not the material which is wicking the heat away.
door
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
You are right that there should be a guide, however for the time being, here is a great video.
https://www.youtube.com/watch?v=EGW9RAkl...
I hope this helps.
Was dit antwoord nuttig?
Score 2
1 Opmerking:
We can’t be dependent on the fantastic iFixit staff to create all of the guides. We also need volunteers to create content as well.
door
Time charges things! In years past the TIM paste was still based on old formulations which tended to break down. Todays TIM is much better! I doubt you’ll need to refresh it to gain enough performance improvement for the amount of work and risk if you’ve not done it a few times before.
I would focus in keeping the fans and heatsink fins clean of dust and debris, as well as dusting off the logic board as well if it’s coated up. I also recommend installing a good thermal monitoring app so you can watch things over time. I find TG Pro is one of the best and it allows you to export the data to a spreadsheet so you can track over days, months or years how your system is doing thermally.
Voeg je antwoord toe
lighscan zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 15
Afgelopen 7 dagen: 78
Afgelopen 30 dagen: 399
Altijd: 3,414
