Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
De HP Pavilion DV9700 is een notebook-pc-model dat in januari 2007 door de Hewlett-Packard Company werd uitgebracht. Het grote scherm en het krachtige geluidssysteem maken het apparaat ideaal voor mediagebruik en streaming-applicaties.
My screen shows black
I am using my laptop as daily , but suddenly the screen turns to Black. And now nothing trick is working
Is dit een goede vraag?
Score 1
1 Opmerking
المرويحاتعمل لكين الشاش لاتعمل
door Deel
Voeg een opmerking toe
2 Antwoorden
Filteren op:
Het nuttigste antwoord
Hi @jaatmafia
Try connecting an external monitor to the laptop's s-video jack or vga jack and check if there's a display from the laptop showing on it. Don't forget to press the Fn + F4 keys (both together) to toggle the display between the laptop screen and the external monitor screen.
If there is a display seen on the external monitor, with the display switched back to the laptop screen, try shining a flashlight at an angle close to the laptop screen and check if you can see any images at all on the screen.
If you can see images then there's a backlight problem with the laptop screen. This could be due to a faulty backlight power supply on the motherboard, a loose or faulty video cable or a faulty CCFL backlight tube in the screen.
If you cannot see any images then this could be due to a loose or faulty video cable or a faulty screen.
If there is no display seen on the external monitor, then this could be due to a problem on the motherboard.
Was dit antwoord nuttig?
Score 2
@jaatmafia if the aforementioned diagnostics and solution does not work, you need to consider that this is a GPU issue. This series of laptop was plagued by the "chip flip" failure.
Your GPU processor is a flip chip design and the issue could be the solder bumps between the IC and the substrate. Sometimes a reflow with a heat gun may just accomplish a temporary repair. It is not a permanent fix, nor is it a sure thing either. It all depends on the individual logic board and the damage to the solder joints as well as the chip itself. A permanent fix would be a total reball. For a reball to be done, you will need the stencil, a rework machine as well as the proper reball temperature template, and a new processor, which by now is most likely no longer available. Yes, you do want to replace the thermal paste as well. Here is a very "quick and dirty" explanation of what causes most of the issues and it is pretty much the same for the YLOD, the XBox RROD as well as multiple others like HP and Apple.
It is not always a failure of the solder balls which connect the Flip Chip BGA package to the motherboard. It does happen and you can see why on here More commonly however is that the failure is due to the chip design itself.
Afbeelding
As you can see the "bumps' are what actually connects the die to the substrate to make the chip complete. If these bumps fail the die does no longer make contact either he substrate and thus no contact with the circuit board. The chip has failed.
Afbeelding
Here you can see the space where the bump has failed and no longer makes contact. We are talking microns of space here. So a bit of pressure on the top of the die potentially close the gap. Same with a reflow, it may allow some of material from the bump to reshape and starting to make contact again. The heating of cooling of the chip during use is what will eventually cause it to fail again.
Score 1
Voeg je antwoord toe
Jaat Mafia zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 41
Altijd: 439
