No image black screen
Is dit een goede vraag?
@cristinejo80172 you forgot to tell us if you have sound. Next turn your TV on Then use a flashlight and shine the beam at an angle against the screen. Do that in a darkened room. See if you can make out shadows or shapes. If you do, then it is your backlight that has failed.
If you do not see anything, unplug your set and remove the back cover. Then visually check the boards for any obviously damaged components. Check all the wiring and unplug the wires and plug them back in, make sure they are properly seated. Post some images of all of your boards with your question. Use this guide Voeg afbeeldingen toe aan een bestaande vraag for that so we can see what you see. It is possible that this is either a power board or a T-con board issue.
Was dit antwoord nuttig?
@oldturkey03 I have the same issue, and did the flashlight in a dark room.
Looks like a backlight issue. Any guides on how to replace it and what parts would be needed? Thank you!
yes me too can i get a guide on hoe to fix it
@rubimosqueda I bought new LED strips from Ebay.
And then followed these two guides from a youtuber.
Full black image
@venu72785 what have you checked and what have you already tried?
Afgelopen 24 uren: 7
Afgelopen 7 dagen: 38
Afgelopen 30 dagen: 171
Altijd: 5,657
18 opmerkingen
door Edwin Lombeh Deel
@edwinlombeh have you tried the steps listed in the answer?
door oldturkey03 Deel
the television does not turn on, but the power on light
door Dani Elsandi Deel
No display only stay on
led indicator
door Dickri Adriana Deel
Tidak ada gambar pas pakai sate box
door KEPETT Deel
13 commentaren meer tonen
