Ga door naar hoofdinhoud
Repair guides, user manuals and services for the Asus ROG Zephyrus G14 laptop. The Zephyrus G14 is a 14-inch Ryzen-powered gaming laptop, first released in mid-2020.
keyboard is dead and backlight is flickering
Hi, some history of my g14 2022, after 10months, my lcd started to have lines, had it replaced by the shop i bought this from. then in one of my travel, my laptop bag fell with my g14 in it, after that, the keyboard stop working adn there is also a slight backlight flicker
. i had to use an external keyboard. i tried to have the keyboard replaced but the repair shop said even with a new keyboard, it still doesnt work. any lead will be appreciated
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
@walterjrgarcia the backlight flickering and keyboard not working could be a torn, loose cable as well as damage to the board connector etc. I suggest that you take a look at those things first. Remove the bottom case as show in step one on here Asus ROG Zephyrus G14 Thermal Paste Replacement check closely for any damage. Post some pictures of what you see with your Question. That way we can see what you see. Voeg afbeeldingen toe aan een bestaande vraag
Worst case scenario would be a new keyboard (upper case) or even a new motherboard. Let's check this all out first.
iFixit Afbeelding
Handleiding
Moeilijkheid:
Zeer eenvoudig
2 - 5 minutes
Asus ROG Zephyrus G14 Thermal Paste Afbeelding
Handleiding
Moeilijkheid:
Gemiddeld
45 minutes - 1 hour
Was dit antwoord nuttig?
Voeg je antwoord toe
Walter Jr Garcia zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 14
Altijd: 395
