Ga door naar hoofdinhoud
Asus ROG Zephyrus G14 Thermal Paste Replacement
jon bush
jon bush en 5 andere bijdragers
Voor het laatst geüpdatet op February 14, 2025
45 minuten - 1 uur
Gemiddeld
Door de gemeenschap gemaakte handleiding
Wat je nodig hebt
Onderdelen
Gereedschap
Toon meer…
  1. Asus ROG Zephyrus G14 Thermal Paste Replacement, Opening the device: stap 1, afbeelding 1 van 1
    • Start by unscrewing the bottom case. There are two different size screws. One long one short.
    • The ones marked in red are the short ones. As for the ones in orange are the long ones.
  2. Asus ROG Zephyrus G14 Thermal Paste Replacement, Unplugging the Battery: stap 2, afbeelding 1 van 2 Asus ROG Zephyrus G14 Thermal Paste Replacement, Unplugging the Battery: stap 2, afbeelding 2 van 2
    • Using a plastic spudger push back the retaining clasp for the battery plug. It is a sliding motion so push it to the right with the battery closest to you.
  3. Asus ROG Zephyrus G14 Thermal Paste Replacement, Removing the cooler: stap 3, afbeelding 1 van 1
    • Marked in red and orange are the screws that hold on the cooler. They are all the same size but I would still keep track of if it was holding on a fan or a block.
    • Marked in yellow are the power and signal wires for the fans. Using a plastic spudger slowly walk the male plug out of its socket.
    • Using the same spudger's flat side pry around the two dies. The old thermal paste will fight back so take your time.
    • Carefully remove the display cable concealed with plastic on the leftmost side of the board - marked in blue.
    • Remove the wifi coax cables (black and white) concealed with plastic to the rightmost side of the board - marked in pink.
    • Only then the cooling unit can be freely removed.
  4. Asus ROG Zephyrus G14 Thermal Paste Replacement, Cleaning and appling the paste: stap 4, afbeelding 1 van 3 Asus ROG Zephyrus G14 Thermal Paste Replacement, Cleaning and appling the paste: stap 4, afbeelding 2 van 3 Asus ROG Zephyrus G14 Thermal Paste Replacement, Cleaning and appling the paste: stap 4, afbeelding 3 van 3
    • You can see where the thermal paste was so make sure to apply it on the same surfaces.
    • I have marked two small parts that are easy to miss.
    • I used 70% rubbing alcohol, tissues, and the flat end of a spudger to remove the old paste.
    • I used a plastic spudger to spread the paste on the chips to make sure that it will make full contact.
    • Replace the cooler by reversing the steps in step 3.
  5. Asus ROG Zephyrus G14 Thermal Paste Replacement, The bottom case: stap 6, afbeelding 1 van 1
    • Button up the device by placing and screwing on the bottom case.
    • The screws marked in orange are long. The ones marked in red are short.
  6. Asus ROG Zephyrus G14 Thermal Paste Replacement, Temps before: stap 7, afbeelding 1 van 2 Asus ROG Zephyrus G14 Thermal Paste Replacement, Temps before: stap 7, afbeelding 2 van 2
    • Before new paste.
  7. Asus ROG Zephyrus G14 Thermal Paste Replacement, The results: stap 8, afbeelding 1 van 3 Asus ROG Zephyrus G14 Thermal Paste Replacement, The results: stap 8, afbeelding 2 van 3 Asus ROG Zephyrus G14 Thermal Paste Replacement, The results: stap 8, afbeelding 3 van 3
    • After new Thermal paste.
    • For the testing, I used 3D mark time spy without the demo. As well as a custom fan curve. The profile was set to turbo for both runs.
Conclusie
14 andere personen hebben deze handleiding voltooid.
jon bush
591 Reputatie
1 Handleiding geschreven
9 Guide Comments
I used metal tweezers and my laptop won’t turn on now. What did I do?
Mason - Antwoord
Did you manage to get an answer to this? I didn't use metal tweezers but my laptop won't turn on and it's blinking as if it's trying to run but it can't!
OVO Architects -
Open up chips and look if there are cracks on chips, if there are, then you got a dead chip.
hazard4636 -
You have probably created a spark between the tweezers and the laptop circuit while the battery power is still on, bring it to a repair shop that provides micro soldering service and let them fix it.
Jerry Li -
I followed this and even used ifixit tools and now my laptop won't boot. No bios, no charge light, no cpu light, no fans. I followed it exactly, grounded myself, didn't touch the motherboard, didn't even get up as to not accidentally generate static, worked on concrete and a wooden table, none of the connections are loose or damaged. It just won't turn on. What happened and how can I fix it?
Daniel Carbaugh (Danny) - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 17
Afgelopen 7 dagen: 217
Afgelopen 30 dagen: 1,196
Altijd: 28,642
