Ga door naar hoofdinhoud
Reparatie-informatie voor de Raspberry Pi 3 Model B. Uitgebracht in februari 2016. Model: B.
Raspberry Pi 3B+: HDMI not working
Hi iFixers. I have a couple of Raspberry Pi 3B+ boards that are fully functional but don't detect and therefore don't show any picture over HDMI. It's not a software bug and the connector is fine. I'd appreciate any hints on what chip controls HDMI output on those boards - maybe I'd be able to replace it
Update (01/29/24)
After spending some time examining things around on the board I believe the fault might be due to the IC pictured below or the components to the right. Does anyone know what those are? Any hints would be greatly appreciated 🙌🏻
Afbeelding
Afbeelding
Afbeelding
Update (01/29/24)
And one more weird detail - on the marked pin I get around 3V on the faulty boards instead of around 1,1V on a healthy one - what might cause this? Is this still that HDMI05-CL02F3 chip?
Afbeelding
Is dit een goede vraag?
Score 1
1 Opmerking
I wonder if LAN7515 C000 chip that controls USB and Ethernet on the Pi also related to HDMI 🤔. Any ideas would be greatly appreciated
door
Voeg een opmerking toe
1 Antwoord
Filteren op:
Het nuttigste antwoord
Hi @insympathy
According to the datasheet the IC only handles USB and Ethernet.
If possible, try tracing the connections back from the HDMI port and see what IC they connect to. Wondering if HDMI is incorporated in the main Broadcom SoC IC
Was dit antwoord nuttig?
Score 2
10 opmerkingen:
Hey, thanks for a hint - I already found that too.
Now the question is the following: Pi shows the graphical interface over VNC perfectly well, so my guess would be that graphical core does work. It's something between the SoC and the HDMI port that stops the party :)
door
@insympathy
Don't know Raspberry that well but have you tried this
door
Tried all of that, thanks, but sadly it seems that it definitely is a hardware issue
door
@insympathy
You've probably already got this but perhaps check if there's 5V on pin 18 of the HDMI port
door
You are absolutely right and I do get at least 4,7V on pin 18 :)
door
5 commentaren meer tonen
Voeg je antwoord toe
in_sympathy zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 22
Afgelopen 30 dagen: 73
Altijd: 990
