Ga door naar hoofdinhoud
Tecno Spark 6 Air mobile was launched on 30th July 2020. The phone comes with a 7.00-inch touchscreen display offering a resolution of 720x1640 pixels and an aspect ratio of 20.5:9. Tecno Spark 6 Air is powered by a quad-core MediaTek Helio A22 (MT6761) processor. It comes with 2GB of RAM. The Tecno Spark 6 Air runs Android 10 and is powered by a 6000mAh battery.
20 Vragen Bekijk alle
My phone speaker is not working
my phone speaker not working
Is dit een goede vraag?
Score 9
2 opmerkingen
My phone battery is not charging
door
My phone blinks
door
Voeg een opmerking toe
13 Antwoorden
Het nuttigste antwoord
There are a few things you can try first:
  • Restart your phone. This is often the simplest way to fix minor problems.
  • Check your volume settings. Make sure that your phone's volume is turned up and that you're not in silent mode.
  • Clean the speaker grills. The speaker grills on your phone can get clogged with dirt and dust, which can block the sound. Use a soft brush or cloth to gently clean the speaker grills.
  • Update your phone's software.Sometimes, software updates can fix bugs that cause problems with the speakers.
Was dit antwoord nuttig?
Score 4
1 Opmerking:
It's helpful
door
Here are some quick fixes for a non-working phone speaker:
  • Check the volume: Make sure your phone isn't muted and the volume is turned up.
  • Restart your phone: A simple restart can often resolve software glitches.
  • Clean the speaker grille: Dust or debris can block the speaker. Use a soft brush to clean it gently.
  • Test with different audio sources: Try playing music, videos, or making a call to see if the issue persists across all apps.
If these don't work, the problem might be more serious and require professional repair.
Score 1
Well check out the following: https://www.youtube.com/watch?v=vAG8B0Dx...
One speker not work
My phone speaker not working
My mobile does not work
Mobile speaker is not working
Update (06/25/24)
1 Opmerking:
My mobile is not working
door
Hello guys,
my phone doesn't vibrate, how can i solve that issue please.
TECNO CAMON15 premier.
1 Opmerking:
Well Checkout the following video it might help you in fixing the issue:https://www.youtube.com/watch?v=W0-_BKzz...
door
Check volume levels
Reboot your device
Adjust the app sound settings
Clear the speaker
Charger not save
Speaker not warking
Screen is not touching
Voeg je antwoord toe
asfaw kefyalew zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 29
Afgelopen 30 dagen: 111
Altijd: 2,206
