Ga door naar hoofdinhoud
The Nintendo DS is Nintendo's seventh generation handheld game console and is the first of its kind across all systems with dual-screen technology and use, apart from clamshell Game & Watch systems.
20 Vragen Bekijk alle
Original DS Broken in half how could I fix it?
I know where to buy the shell cause but idk what or where to buy everything else
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
I'd start by disassembling both halves and seeing what's still intact. Obviously anything running through the hinge has to be replaced (two ribbon cables and a wire as far as I can tell). I can't tell what they connect to, but they should be easy enough to find once you figure that out. If you need help ID'ing anything, post a pic or two, we'll be here
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Angel Zuniga zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 6
Altijd: 90
