Ga door naar hoofdinhoud
De Sony Ericsson W580i is een slider-telefoon in Walkman-stijl met een 2 megapixelcamera.
Lines on the display
Hello everyone. I have a Sony Ericsson W580Ii with a screen issue. It dropped on the ground (not on display side, but dropped on the back) and after that accident, I see lines on the bottom sides of the display. Can it be an internal flexible cable connecting the two halves of the phone, flexible cable connecting the display to the motherboard or the LCD the problem?
P.S.: I'll insert a photos to describe the problem.
Afbeelding
Afbeelding
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Hi @stanislavaz2584
I think it looks more like a problem with the LCD display. Even if it did land on the back of the phone when it fell, the shock when it hit the ground could have been enough to cause internal damage to the display
Here's the ifixit Sony Ericsson W580i LCD-scherm vervangen guide that will help.
At least you can check the cable connections etc to make sure it is OK.
If you think that it is the display then search online for Sony Ericsson W580i Display (LCD) to find suppliers that suit you best.
Here's the service manual as well that may also help.
Was dit antwoord nuttig?
Voeg je antwoord toe
Stanislava Zubkova zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 14
Altijd: 287
