Water pours out of the drain pump filter
I have an LG washer model WM3400CW.
Whenever I clean the drain pump filter, I get just a little water from the mini hose, but a lot of water pouring out when I unscrew the drain filter. Is that not supposed to happen?
Does it indicate there's a problem with the mini hose? The mini hose does not seem to be clogged - I probed it with a long zip tie and squirted water into it with a turkey baster. When I used the turkey batter, the water came out of the filter opening (filter was removed at the time.)
Appreciate your help!
Is dit een goede vraag?
6 opmerkingen
@nancystaab this was converted from a comment on an old question to its own question. That way you may actually get a solution. Hope our experts @jayeff et al will catch this one.
In the meantime, we would need your washers exact model number.
door oldturkey03
Hi @nancystaab
Is there still any water in the drum before you undo the drain filter?
Have you checked if the main drain hose from the washer is clear?
Also is the filter OK and not clogged?
door jayeff
Hi @jayeff,
Thanks for your reply!
There is no water in the drum when I remove the drain filter. The filter is ok and not clogged. I have not checked if the main hose drain is clear.
door Nancy Staab
@nancystaab
Regarding the main drain hose, if it is clear, then if it is inserted into a drainpipe check that there's a high loop before it enters the drainpipe i.e. loop higher than the drain
Also make sure that the drainpipe itself drains quickly and doesn't drain too slow or backup when water is poured down it so that there is no siphoning back into the washer from the drain due to the water not getting away quick enough once the water has finished being pumped from the machine
door jayeff
I will check the main drain hose and drain pipe, and report back.
door Nancy Staab
1 commentaar meer tonen
