Ga door naar hoofdinhoud
Released March 2010. Model number FA1-0062-06.
How can I tell if the problem is the fuse?
How can I tell if the problem is the fuse? Is there “a tell” that the problem is the motor or circuit board before searching for fuses? For the 1st micro second it moves an inch like it’s getting power.
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Use a multimeter and test it for continuity:
Vornado Duo Fuse Replacement
Was dit antwoord nuttig?
@djlaine17 you can't, until you test it with a multimeter. If you have not done this before, check something like [https://www.youtube.com/watch?v=Kxl-IjEl... |this video for the How-To.
This "micro second it moves an inch" leads me to believe that it is not your fuse. When the fuse is "blown" there is not power going through the circuit. None. That means you would not get ANY movement. The issue you are describing sounds like either a capacitor issue or a motor driver issue. Once you checked the fuse to verify, check the circuit board Vornado Duo Circuit Board Replacement for any obviously damaged looking component or burned traces etc. Post some pictures of what you find/see with your question. That way we can see what you see. Also, make sure that tell us the exact make and model of your fan
Voeg afbeeldingen toe aan een bestaande vraag
iFixit Afbeelding
Handleiding
Moeilijkheid:
Zeer eenvoudig
2 - 5 minutes
Vornado Duo Circuit Board Afbeelding
Handleiding
Moeilijkheid:
Gemiddeld
9 - 10 minutes
Voeg je antwoord toe
Djlaine17 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 4
Altijd: 290
