Why is my mic headset audio coming out as static
*couldn’t get a physical shot of front I/O* Ihave my headphone plugged in to the front of my pc the audio works perfectly fine but the input audio makes it sound heavily static I tried it with a different headset and same result and I am wondering what it could possibly be
Is dit een goede vraag?
8 opmerkingen
Just to confirm, are you using separate plugs for mic and speakers, or a combo plug for them? And are you plugging in to the rear the same way, and getting different results? If you could provide a photo of your front I/O panel that would be great. (To add photos to your question, see here: Voeg afbeeldingen toe aan een bestaande vraag)
door Justin Castle
It is a combo headset that has a mic and speaker I haven’t tried the back one yet
door Platinum Chest
So i can only plug this one in the front since it’s the mic and speaker in one 3.5mm headphone jack audio very good but the microphone is just all static when I talk
door Platinum Chest
@platinumchest "It is a combo headset that has a mic and speaker"
Do you mean both Mic and Speaker share a single 3.5mm plug? If that is the case, my leading theory is going to be your front I/O has a separated socket and, thus, the socket you're plugging into doesn't have a dedicated channel for microphone. Static is typical for such issues.
You would need a reverse splitter, such as this (https://www.amazon.com/dp/B07PBSTHDS/). You plug your single combo 3.5mm jack into the female port of the splitter, then plug the "mic" side of the splitter into one socket for the microphone, and the "headphones" side of it into the other, and you should be good to go.
door Justin Castle
Yeah there both on 1 I though the front i/o socket was for both since it has the symbol for both a mic and headphones
door Platinum Chest
3 commentaren meer tonen
