Ga door naar hoofdinhoud
How can I upgrade this model to Win11
When will the opportunity arise?
Maybe there is another way?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
If your device has a processor or other some other hardware hardware component that isn’t compatible with Windows 11, last I knew there were still some cheats to install it anyway. Although, I believe it will require a fresh install of the OS, rather than upograding your existing OS. It has been a while since I did this.
Because the installation media for both are very similar, you can just put the Windows 11 files into the Windows 10 installer and your machine will allow it to install because it thinks it’s installing Windows 10. I got this to work on a crummy old Toshiba Satellite with a garbage AMB A6 processor and 6 GB of RAM.
There are a bunch of additional caveats and things to pay attention to. Depending on the actual specifications of your machine, Windows 11 may not perform super well. But I know Vostros typically have business class processors (V-Pro) And Microsoft was really narrow minded about official processor compatibility.
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
Sprendimas zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 4
Altijd: 155
