Ga door naar hoofdinhoud
The fifth generation van had debuted at the 2007 North American International Auto Show with exterior styling by Ralph Gilles.
20 Vragen Bekijk alle
Abs light is on
I'm looking for help with abs repair, the light has been on for a long time, the van runs good but I'm hoping to fix instead of ignoring I had to get a new transmission and the local mechanic couldn't figure out what the abs issue was
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
There are many reasons why your ABS light might be on. In order to read the codes, you need a scanner that can read those code, which will give you a place to start. The most common reasons for ABS problems is a defective sensor or ABS module.
Was dit antwoord nuttig?
Voeg je antwoord toe
Rocks Solid zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 3
Altijd: 43
