Ga door naar hoofdinhoud
De LG VX5200 is een CDMA-klaptelefoon met een externe antenne, 32 MB aan intern geheugen en een 1000 mAh Li-ion-accu.
SIM card slot location?
Where is the slot for a SIM card located on my LG VX5200? Is there one? If not, what do I need to do to make the phone able to recei
Is dit een goede vraag?
3 opmerkingen
If I don't see were to place my sim card what should I do to receive calls
door
Per my previous email. RTFM. See above.
door
@hassangabr19854 just as explained in the answers below :-) there isn't one.
door
Voeg een opmerking toe
2 Antwoorden
Filteren op:
Het nuttigste antwoord
Hi Tess,
That particular phone was made pretty much exclusively for Verizon, and didn't come with a SIM card slot, since it only works on Verizon's CDMA network. It wasn't until the iPhone 5 that iPhones on Verizon started using SIM cards, and it's about that time frame that other phones that ran on Verizon also started using SIM cards.
Unfortunately, the phone does not support 4G networks so Verizon is not going to let you activate it on their network; they've phased out their older 2G technology and 3G is on its way out as well. So unless you can find another carrier that still supports the CDMA network, that phone is pretty much going to be a pretty brick.
Was dit antwoord nuttig?
Score 1
@tess85230 is a CDMA phone that does not use a SIM card. You will need a provider (used to be Verizon) that still supports your phone to see what needs to be done to get it activated. Check this Wiki for more info on your phone. LG VX5200 Troubleshooting
Voeg je antwoord toe
Tess zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 17
Altijd: 1,193
