Ga door naar hoofdinhoud
Released in Japan on December 12, 2004, in North America on March 24, 2005, and in Europe on 1 September, 2005.
90 Vragen Bekijk alle
How to repair my psp when can't on power
my psp 1000 can't on and when my battery full also can't working....
Is dit een goede vraag?
Score 7
3 opmerkingen
I have the same problem too!!
I checked the batery, the power is connected to the motherboard.
door
How do I do that
that
door
i have problem with my psp start and l buttom
door
Voeg een opmerking toe
3 Antwoorden
Het nuttigste antwoord
Look at the DC port on the PSP. Does it have the little metal pin sticking out of the middle? It is also possible that the switch on the power board may no longer work. Pick any of the guides listed on here PSP 1000 and open the PSP up and see if you can hold the power board still, plug it in and try flipping the black switch to see if it'll turn on that way. Of course there is also the possibility that your power fuse is blown and that you have an interrupted circuit. check on here for much more info about that. Hope this helps, good luck.
Was dit antwoord nuttig?
Score 6
7 opmerkingen:
i will try it....thank for teching....
door
but me is 3006 modal...can help??
door
ginz.. this is the guide for you PSP 300x Repair, I'm not sure that the fuse is in the same spot..If you need further help then please start a new question.
door
where the 300x fuse and i think board spot...
door
uuuum...Does this work on Non-Sony PSP...cause my PSP is not sony
door
2 commentaren meer tonen
check the batery and the power on button.
Score 1
I had seen on Youtube if you repeatedly push up the power button, it might turn on. Worth trying
Voeg je antwoord toe
ginz zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 37
Afgelopen 30 dagen: 157
Altijd: 32,594
