Ga door naar hoofdinhoud
The first model of iPhone, Model A1203 with 4, 8, or 16 GB capacity and an aluminum back. Repair requires a significant amount of prying, and may require some soldering. This page aims to help users troubleshoot, fix, and seek help for the iPhone 2G.
20 Vragen Bekijk alle
Help! iPhone stuck in boot loop with weird shadowing on screen
im planning on replacing the display, just need to find a part with a digitizer and lcd with all the small parts
it only turns on when its plugged in as shown in the video, and has a weird shadowy affect after it turns itself off.
anyone know what to do?
ive tried putting in in dfu mode while its doing this,hard resetting also, and it doesn't help
is this also a display issue/recovery issue or is it something else?
I GOT TO GO INTO RECOVERY MODEEEEE
okay but is it compatible with the newest itunes update?
what do i need to do to actually recover this phone?
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
are you concerned about data on the phone?
if not, then i'd recommend downloading 3utools and installing it on your PC. put the phone into DFU mode (you will need to google how to do this for your model), connect it to your PC and execute a anti-recovery Flash.
this will install the latest firmware and IOS for your phone.
this usually works for me when i get bootlooping phones to evaluate - but only if the data is expendable.
Was dit antwoord nuttig?
Score 1
3 opmerkingen:
@beekerc
is there a version for mac?
also i don't mind the data, i bought this phone off ebay to repair
door
also the phone turns off before i can put in dfu i only can barely get recovery mode to work in time before it shuts off it only stays on for about 10 seconds before turning off:(
door
@timtomissus
no. 3utools is for pc only, sorry
door
Voeg je antwoord toe
timtom77 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 7
Altijd: 167
