Doorzoek deze discussie om de juiste plek te vinden voor je opmerking. Klik vervolgens op "Link je opmerking aan dit bericht" om je opmerking te verplaatsen.
I'm having the same issue with what looks like almost the same exact monitor: LG 27GL650F-B. Seems like a power surge happened even though I have a surge protector because the monitor flickered, then shut off, and hasn't been able to turn back on since. What tools do I need to fix this and does anyone know how?
@ryanarther if anything it'll most likely be the power board. You will have to disassemble your monitor and check the board. As for tools, commonly just a few hand tools (screwdriver set) will do. You may need more once you know what is wrong with it, but for now, just disassemble and evaluate.
Can you disassemble the monitor, then upload pictures of the circuit boards? Voeg afbeeldingen toe aan een bestaande vraag
door Andrew S
jackmotimele104 are you saying that the monitor does not want to turn off? It is on all the time?
door oldturkey03
Did you try another External Power Supply?
door Ben Capehart
door Ryan Arther
door oldturkey03
