Is there a way to fix the headphone jack?
Mine sounds very tinny, it wasn't like this before.
I think the jack is faulty as it sounds a bit better if i press the metal back and the front panel together.
Is dit een goede vraag?
Krijg snel toegang tot handleidingen, onderdelen en antwoorden voor jouw apparaten
Hi
You could try cleaning the jack with some isopropyl alcohol and a Qtip/cotton buds
If you decide to try this don’t pour the alcohol into the jack ,dip the cotton bud in it then clean until it looks clean
If that doesn’t work it could need replacing or repairing
Here’s a guide on disassembling the iPod
iPod Touch 3rd Generation Logic Board Replacement
Once disassembled you will need to ether reflow the solder joints or desolder the Jack depending n if your replacing it or not
Here’s a link to the part you may need
https://www.ebay.co.uk/itm/190748878434?...
Hopefully this helps
Any questions please ask
Was dit antwoord nuttig?
Thanks, will give cleaning the jack a shot!
@Syamantak Das
Good luck!
I find it’s usually one of the two things
Cleaning usually helps:-)
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 6
Altijd: 59
