Ga door naar hoofdinhoud
Casio CFX-200 uitgebracht in 1983, basis van verchroomd metaal. CFX-20 Zwarte kunsthars met dezelfde module (niet afgebeeld) Modulenummer 197
How do I reinsert the Cfx-200 module?
The module for my Casio CFX-200 is not fully seated into the case so some of the buttons are not working. I see that the buttons on the sides slip and interfere with the leaf springs on the module, is there a trick to getting them out of the way?
Is dit een goede vraag?
Score 2
3 opmerkingen
Can you attach pictures?
door
@johnftexas it'll help if we can see what and where you are stuck with it. Post some images with your QUESTION. You need to edit it and follow this guide Voeg afbeeldingen toe aan een bestaande vraag
door
How do you remove the module from the case? I need to access some sticky side buttons. Thanks in advance
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
So I took it back apart to take some photos of it then I decided to try again. I used a sewing needle to reach between the module and the case to push each side button in this allowing the module to seat further in. Long story short… it’s working about as well as when I got it in 1987😀. Thanks for your rapid response and I will remember to include photos next time I have a question.
JohnFTexas.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
John Finnell zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 23
Altijd: 783
