Ga door naar hoofdinhoud
Repair and disassembly information for the Logitech MX Master 3S wireless mouse. Released in 2022 and identified by model number MR0077, and part numbers 910-006557, 910-006558, or 910-006556. Other regions or model iterations have slightly different part numbers, such as 810-008296 for the graphite variant sold in Canada at launch.
11 Vragen Bekijk alle
Logitech MX Master 3S get wet!
Logitech MX Master 3S get wet and stop working. I have disassembled few times, used electronic cleaner for all boards but no success. Charging light always red regardless how long I am charging. What to do?
Is dit een goede vraag?
Score 1
2 opmerkingen
Thanks for suggestions. I did everything: remove all boards completely, cleaned all visible spots that possibly from water. But I have used CRC brand QD Electronic Cleaner. My concern about lithium battery. Its label says 4.2V, but can be charged up to 4.1V only.
Do I need to replace it? Again, regardless how long I am charging - red light (mouse indicator) always present, not green.
door
Igor Vysoc that voltage is ok. But it is not enough to test the voltage to prove that the battery is okay. If it got wet etc, I would replace it as well.
door
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
Igor Vysoc you did not tell us if you removed those boards. If you did, post some pictures of those with your QUESTION. Voeg afbeeldingen toe aan een bestaande vraag
It is always best to remove and to properly clean everything with some high grade isopropyl alcohol. For a proper cleaning, use this guide. Repairing iPhone Liquid Damage It was written for a Apple iPhone 3G but it is still pertinent to your mouse as well. Truly assess the damage. Look for major corrosion, evaluate the pins in the connectors etc,. Take a look at all connectors as well as cable ends. Once properly cleaned, REPLACE THE BATTERY and reassemble to re-evaluate.
iPhone Afbeelding
Handleiding
Moeilijkheid:
Moeilijk
1 - 2 hours
iFixit Afbeelding
Handleiding
Moeilijkheid:
Zeer eenvoudig
2 - 5 minutes
Was dit antwoord nuttig?
Score 3
Hi everyone I made the same mistake. My left button got stuck and I didn’t want to open the mouse and I tried with contact spray to spray in the holes of the left click. But then the mouse stopped working. The red light is blinking, then I open the mouse there is no visible issue. I disconnect the battery tried to connect directly with cable but still got the red light and no option to connect with any device.
1 Opmerking:
I have the same and exact scenario as you, my left button out of nowhere just stopped working. I tried to clean with a contact cleaner, when I switched it on again - then the red light is blinking. This is a very frustrating issue, and it's seems like the issue is repeatable with others. This must be something to do with there firmware and this is not a hardware issue - maybe, just maybe, Logitech is doing this on purpose.
Have you tried to fix it? I love this mouse, if it doesn't work anymore I have no choice but to buy again.
door
Voeg je antwoord toe
Igor Vysoc zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 21
Afgelopen 30 dagen: 62
Altijd: 2,308
