Ga door naar hoofdinhoud
This Nintendo DS Lite was released in 2006 as the successor to the Nintendo DS. Getting inside this device is simple, making for easy fixes.
How to unscrew a stuck screw?
I was going to disassemblee the Nintendo Ds Lite. Unfortunately, one of the screws on the back cover is stuck. I also tried to use a particular product used for the stucking screws but nothing happens.
Can you please help me?
EDIT: the screw is located here
Is dit een goede vraag?
1 Opmerking
The same screw is stuck for me too.
door
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
@twiggy7 sometimes it is just a matter of using a different screwdriver. Something with some sharp hardened edges is usually best. Apply plenty of downward pressure when trying to loosen the screw otherwise it'll chew up the screwhead. If that already happened it is best to use a small drill or Dremel to remove the screwhead. Once disassembled you will need to use a pair of pliers to remove the rest of that screw. Again, it will all depend on where the screw sits and what it all looks like. Adding images to an existing question - iFixit Repair Guide
Was dit antwoord nuttig?
Score 1
2 opmerkingen:
Thanks for the adviceses! I'll try with another screwdriver.
Also, I added a photo in which shows the position of the screw I'm going to unscrew.
door
Yes, I was afraid it was one of those. Can't use a Dremel on that. Hopefully a good screwdriver will help with that. Otherwise it's the drill.....
door
Voeg je antwoord toe
Titti Smile zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 35
Altijd: 755
