Ga door naar hoofdinhoud
Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Vragen Bekijk alle
My iPhone 6 fell in water and won't turn on
my iphone 6 fell in water and won't turn on
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
Hi
The impurities in the water causes corrosion and provides circuit paths for the electricity which were not in the phone's operating design and could damage the components. The corrosion starts immediately and is ongoing until it is completely cleaned away
First do not try to charge or to turn on your phone and then remove the battery as soon as possible from the phone to minimize any further damage.
Then you need to dis-assemble the rest of the phone and clean all the affected parts using Isopropyl Alcohol 99%+ (available at electronics parts stores) to remove all traces of corrosion and water. If possible do not use "rubbing alcohol" as in some cases this is only 70% IPA or less, can contain additives and is not as effective. If you do have to use it check the label to verify the amount of IPA. The higher the percentage of IPA the better
Here are a couple of links that describes the process.
Electronics Water Damage
Repairing iPhone Liquid Damage
As always with electronics, especially surface mounted pcb be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board. Remove the shields that may be covering some components as the water may have got in under there. The ends of any flex cables and their connectors need to be cleaned as well
Hopefully after you have done all this the phone might possibly work correctly again.
Here is the ifixit iPhone 6 guide for repairing your phone.
If this process seems too daunting, take your phone to a reputable, professional phone repair service, experienced in liquid damage repair and ask for a quote for a repair. If you decide to do this, do it sooner than later.
Was dit antwoord nuttig?
Score 2
Hi
Sorry to hear about your iPhone but we have got to act fast on this one!
If possible you should take battery out by following this guide here
iPhone 6 Vervanging van de batterij
Ok now we have a bit more time, once that’s done I would remove the logic board by following this guide here
iPhone 6 Logic Board Replacement
And also remove the shields and inspect the board for corrosion(usual looks green ,white or blue)and remove it with a cotton bud/Que tip and some 99% isopropyl alcohol
If that doesn’t work I recommend you take it to a trusted repair shop as it could be a more board level issue
Hopefully this helps
Any questions please ask
iPhone 6 Batterij Afbeelding
Handleiding
Moeilijkheid:
Gemiddeld
30 - 45 minutes
iPhone 6 Logic Board Afbeelding
Handleiding
Moeilijkheid:
Gemiddeld
30 minutes - 2 hours
Score 1
Voeg je antwoord toe
Abdallah Ghanem zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 35
