Ga door naar hoofdinhoud
The laptop automatically turns off every time.
When I use my laptop(DELL VOSTRO 2420), it automatically shuts down every time I use it. Sometimes it shuts off after 20 minutes, sometimes in five minutes. How do I resolve this issue?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Hi Balaji D,
Can you elaborate a bit on this? Are there any symptoms?
Do you get any warning messages or anything?
I would first start with installing HWMonitor and keep that running, and monitor it. See if it's a spike in temperature just before it shuts off. It could very well be high temps that makes it shut off, which can be caused by several things.
  • Old thermal paste that needs replacing
  • Clogged up fans and / or air vents
  • Dust buildup inside that prevents air flow for cooling
Was dit antwoord nuttig?
Score 1
1 Opmerking:
Hi Anderson,
There were no symptoms but it will shuts off only when we use certain applications.
I will try what you have suggested.
Thank you!
door
Voeg je antwoord toe
Balaji D zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 10
Altijd: 184
