Printer will no longer fax
My printer will no longer fax or answer. Line to printer tests good. Everything else works perfectly with the printer. When is goes to fax I get a notice that "unable to send or receive faxes".
Is dit een goede vraag?
Hi @jimwsr ,
Try running the test fax setup from the printer control panel and check what it shows. See p.220 in the manual
Was dit antwoord nuttig?
define "LINE IS GOOD" and how you know?
Is the scan and fax method is ON?
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 20
Altijd: 444
2 opmerkingen
I plugged the cord from the wall into an old fashioned phone.
What do you mean,"is the scan and fax method on"/
door James Wildgust, Sr.
@jimwsr I read that in a google search about your problem. I have no idea what that is, and if you don't maybe that is your problem.
door bill
