Ga door naar hoofdinhoud
Handleidingen voor het repareren van popcornmachines en popcornpoppers.
But heater is not working
Warm light turning on. But heater is not working
Is dit een goede vraag?
2 opmerkingen:
MOHAMMED THAJUDDEEN do you have a make and model for this popcorn maker? If not post some good pictures of it with your your QUESTION. Voeg afbeeldingen toe aan een bestaande vraag
door
I have a Dash popcorn maker sold in Walmart. It was very good until I put the plug in a wrong outlet at 220. It looked like it was on fire. After that it didn't heat up enough to pop the corn. Can this be fixed easily?
door
Voeg een opmerking toe
1 Antwoord
***MOHAMMED THAJUDDEEN we would need to know what make and model your popcorn maker is or at least see more of it. Since the warming light turns on it stands to reason your unit gets power. In that case I would suggest you use an Ohmmeter and measure the resistance on your heating coil to see if it has continuity or if it has failed. You also want to check for power as well as check out the thermostat etc. We really would need to know the make and model or at least see more of the unit/wiring etc. to be more specific. Voeg afbeeldingen toe aan een bestaande vraag
Was dit antwoord nuttig?
Voeg je antwoord toe
MOHAMMED THAJUDDEEN zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 17
Altijd: 411
