Ga door naar hoofdinhoud
Wi-Fi only version of Apple's 2nd generation iPad Air. Model A1566.
Why no Battery health on ipad?
Why is there a battery health on iPhone, but not on iPad ?
Apple introuded Battery health for conveniently for the user for self-check about how good their battery holding up (since new), although i tend to think that is a marketing gimmick..... Unless there something in the battery that Apple can use to monitor how the aging process direly, its just a guess.. That's all it is...maybe a very good one, but has iFixit or community know how this works?? if there is something inside the battery (for accuracy) monitoring?
Secondly, Apple introduced this only in iPhone's after the debacle of users filing lawsuits over slowing down older devices. not before..
My point is they introduced this feature only AFTER complaints happend, which would be with it doesn't exist on iPad.. Is Apple just waiting for the same batch of issus to happen to older iPads before they introduce battery health there too? Will it even come to at all?
As to the technology aspect, there is no reason why iPad is forgoten,, because it uses the same battery tech. Therefore, if it exists on iPhone, but not on iPad, then it was only introduced on phone to bring customers back to Apple and reassure "we've got your loyalty again"
Any reason this did not exist ? Perhaps i'm totally wrong. but if am am, you gotta admit, its a really good coincidence it happened "at the same time"
Update: I did find this : https://www.reddit.com/r/ipad/comments/p...
however, still does not answer on the option was not there in the first place as with iPhone
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
The issue was originally related to iPhone's being throttled at a certain battery health without the user being notified. It does not seem that they throttle iPads in the same way when the battery degrades or at least no one has proved it like on the iPhone side. If you are trying to find the battery health on an iPad, I recommend using software like 3U Tools (PC) or Coconut Battery (Mac) to read the data. They work across all iOS devices and give you pretty accurate data regarding batter health. We use these just to confirm that what the device says in iOS actually matches what the software is pulling.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
na na zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 4
Altijd: 399
