Ga door naar hoofdinhoud
The ASUS Q405U is a laptop produced by ASUS that was released in 2017. It is Intel Generation 5, uses Windows 10 and has many connectivity options.
4 Vragen Bekijk alle
Green line in my laptop screen
  1. Hello All, i have green line in my laptop screen it appear afer half hour when i turn my computer on, he become bigger and more clear afetr some 30 - 40 minute and when i put my comuter in standby and turn him on it disapear, and after some while he appear again, when i put externel screen i have no green line (i also disabled my GPU and still the same ) pls can anyone help me and thnx . (sorry for my bad english)
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Hook the laptop up to an external display and see what happens. If the issue does not persist on the external, the LCD has a TAB failure and you will need to replace the screen.
However, if the display is bad it isn’t cheap. Expect to pay around ~$144-158+, depending on who is selling it. The panel is fused to the glass with UV LOCA glue, so you need to replace the touchscreen assembly as a unit — it can’t be done piecemeal on these.
Was dit antwoord nuttig?
Score 3
Voeg je antwoord toe
fedi dayeg zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 17
Altijd: 1,153
