Lg front loading washer does not dispense water into the softener side
Our front loading lg washer does not dispense water into the softener dispenser. Have done all the cleaning and testing to make sure it siphons but it does not work when washer is in use. Softener is still in cup.
Update (02/01/2022)
The model number is WM3670HWA.
Is dit een goede vraag?
3 opmerkingen
@sandysnow1 what is the exact model number for your washer?
door oldturkey03
I am in for the answer to this as well. I have the same problem. Softener stays in tray during cycle and doesnt seem like it gets any water (not diluted at all end of cycle). Things I have checked or done:
1.) cleaned tray and compartments thoroughly
2. ) checked and clean inlet water screens
3.) ran diagnostics by pushing spin/cycle buttton and power but at same time and ensure the 3 water solenoids are working
4.) checked solenoids with ohmmeter and verified continuity
5.) ran diagnostics via phone app and came out fine as well
One oddity is that when you take the top off and look at dispenser housing the 3 hoses coming in are lableled as “main wash'“ “pre wash” “bleach” but there isn’t a 4th one labeled softener so I got to think that one of those 3 is supposed to put water into the softener tray too, but which on? If it comes into the “prewash” inlet, how is that supposed to divert to prewash or softener if there is no mechanical method?
door Brandon Caley
Same model and the same exact issue. However, this issue happens intermittently from load to load. Sometimes the fabric softener would be fully dispensed, other times it wouldn't.
door Chang Cai
