Ga door naar hoofdinhoud
De zesde generatie van Apple’s draadloze basisstation, uitgebracht in juni 2013. De tower biedt draadloze toegang met ondersteuning voor dual-band en is Apple’s eerste router met 802.11ac-technologie.
low read/write speed ethernet
i have this model but(a1470) with HDD 2tb USA version, wifi normal but speed write and read is very low(only 10-15 mb/s) instead 40-70 mb/s another users.
COnnected to PC windows with Ethernet and on PC motherboard LAN 1000mb/s
What should i do?
Is dit een goede vraag?
Score -1
1 Opmerking:
question does not give enough info to diagnose.
how are you determining speed?
are you saying wifi speed is normal but Ether speed is not?
Internet speed is upload/download not read/write - what are you talking about?
door
Voeg een opmerking toe
1 Antwoord
Filteren op:
Why Your Hard Drive Gets Slow
HDDs and SSDs are commonly used in your daily life to store films, games, and other files rather than with a flash drive or a DVD. However, sometimes a hard drive may become slow to read and write, and for no obvious reasons. To find out the reasons and solve the slow hard drive issue better, you should give you a head start on understanding what causes slow performance.
  1. 1. Torrents and P2P software
  2. 2. Insufficient power or USB ports
  3. 3. Not enough free hard drive space
  4. 4. Logic errors and bad sectors
  5. 5. Damaged disk
  6. 6. Hardware failure...
Now that you have known the reason why the hard drive takes a long time to read, you can follow the fixes to solve your problem and speed up your hard drive easily.
Fix 1. Upgrade the Hard Drive
Fix 2. Uninstall Unwanted Programs
Fix 3. Check the Speed
Fix 4. Switch the SATA
Fix 5. Clean Up Junk Files
Was dit antwoord nuttig?
Score -1
Voeg je antwoord toe
Alex U zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 14
Altijd: 293
