Ga door naar hoofdinhoud
Wi-Fi only variant of the fifth generation of iPad, released in March 2017. Available with 32 and 128 GB storage options featuring a 9.7" Retina display and 64-bit A9 processor.
20 Vragen Bekijk alle
Replacement iPad 5 Home Button doesn't fit replacement screen properly
In the process of replacing the screen of my iPad 5, I tore the home button cable. Ordered both the screen and button from iFixit, yet the button does not seem to sit properly in the screen, as if the hole is too small. Is it expected to fit in the hole or “float” on the backside?
I also ordered a replacement home button bracket, but it slightly differs from the original as there isn’t a little metal “button” on the inside that appears to be pressed against the center actuator of the button.
Update (01/07/2022)
It appears to be the glass as the original home button won’t fit into the glass either but the new home button WILL fit into the original glass. I am going to assume that I need an RMA, but will wait to see if anyone else chimes in or has any recommendations.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
I would RMA sounds defective
Was dit antwoord nuttig?
Voeg je antwoord toe
Sean zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 53
