Ga door naar hoofdinhoud
The Nintendo 2DS is a handheld gaming device developed as an entry level version of the Nintendo 3DS with nearly identical hardware, but without the 3D upper screen function.
20 Vragen Bekijk alle
How do I fix striped screws?
I recently bought a 2ds to play on but it came in with a broken screen. I didn’t feel like returning it because the repairs look easy. When I was unscrewing the back screws I added too much pressure so in result two of the screws became striped of its grip. I tried a few methods like using a rubber band, using a bigger screwdriver, and using super glue to a stick a popsicle stick to the screw. None of the methods worked and now am stuck and don’t know what to do.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
If you don't want the screwdriver or the stripped screw back, (unless you can remove super glue) superglue the screwdriver to the screw.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Romeo2004x zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 7
Altijd: 184
