Ga door naar hoofdinhoud
Reparatie-informatie voor de herziene Pixel Buds van Google—volledig draadloze oordopjes die voor het eerst werden uitgebracht in april 2020. Soms aangeduid als de Pixel Buds 2 of Pixel Buds 2020.
Can you replace the battery?
The pixel buds disconnect whenever they are removed from the case. I think the batteries are bad. Is it possible to replace the battery?
Is dit een goede vraag?
Score 2
1 Opmerking
I'm not seeing replacement batteries for the buds themselves, and the process looks pretty destructive. These aren't made to come apart.
door
Voeg een opmerking toe
2 Antwoorden
Filteren op:
Gekozen oplossing
Hi,
Here’s the Ifixit Demontage van de Google Pixel Buds 2 guide which shows how to open the ear buds.
The guide was only to show the internal components and is not intended as a repair guide because of the damaging way in which the earbuds have to be opened.
The battery is a Varta CP1240 A3 (supplier example only) if you think that you want to try and replace them
Was dit antwoord nuttig?
Score 3
1 Opmerking:
If anyone is attempting this repair, I had good results with using a pair of pliers and gently applying enough pressure to bend the plastic slightly to crack the seal with minimal damage to anything else
door
Het nuttigste antwoord
I don't believe it is possible to open these earbuds without damaging the casing. Therefore, you cannot replace the battery.
Score 3
Voeg je antwoord toe
Joshua Stouffer zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 22
Afgelopen 30 dagen: 78
Altijd: 9,778
