Ga door naar hoofdinhoud
The second-generation Pixel Buds wireless earbuds made by Google and released in April 2020.
3 Vragen Bekijk alle
Can you replace the battery?
The pixel buds disconnect whenever they are removed from the case. I think the batteries are bad. Is it possible to replace the battery?
Is dit een goede vraag?
1 Opmerking
I'm not seeing replacement batteries for the buds themselves, and the process looks pretty destructive. These aren't made to come apart.
door
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
I don't believe it is possible to open these earbuds without damaging the casing. Therefore, you cannot replace the battery.
Was dit antwoord nuttig?
Score 2
Hi,
Here’s the Ifixit Google Pixel Buds 2 Teardown guide which shows how to open the ear buds.
The guide was only to show the internal components and is not intended as a repair guide because of the damaging way in which the earbuds have to be opened.
The battery is a Varta CP1240 A3 (supplier example only) if you think that you want to try and replace them
Score 2
Voeg je antwoord toe
Joshua Stouffer zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 54
Afgelopen 30 dagen: 228
Altijd: 6,377
