Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
De JBL Go 3 is een compacte, draagbare Bluetooth-luidspreker met een IP67-classificatie voor water- en stofdichtheid, die bij een opgeladen accu tot 4-5 uur speeltijd biedt. Het apparaat staat ook bekend als de JBLGO3. Dankzij het compacte ontwerp is hij gemakkelijk mee te nemen en geschikt voor gebruik buitenshuis.
no Red Light while charging
Hi, I just bought a Go3 a few weeks ago, but by mistake my brother at some point put it to charge with a Samsung 15 watt fast charging charger, the speaker works perfect but apparently the red light when charging no longer lights up, everything else works perfect, even the white light is still on while in use. Although it may not be of much importance, but not having the red light does not allow me to know exactly when the battery is low (normally it blinked) or worse, even now I do not know when it is fully charged. So, what should I do? any idea, suggestion? or nothing to do and better buy another? thank you all
Is dit een goede vraag?
1 Opmerking:
UPDATE:
After my problem arose, I decided to continue using my Go 3 and completely forget about the failure, then I recharged the battery using its original cable as always but this time connecting it to the USB port of my Mac mini 2011. The red light never ever returned until the today. "What I think is that ... probably when it was erroneously recharged using fast charging from a Samsung cell phone, the battery or charge manager was" out of calibration "(is what I think). several times with the "proper" load, the speaker recalibrated (if what I'm saying makes any sense). Thanks for your help. No need to open the speaker, I was afraid of damaging it.
door Deel
Voeg een opmerking toe
1 Antwoord
Filteren op:
@hotdavesweet sounds like there are issues with either the battery or the power management IC. I would take a look that the board and check for obviously damaged components and at minimum replace the battery. Use something like this video to work on it. As always, if in doubt or unsure of what you are looking at, you can always post some good pictures and we will try to assist you.
Voeg afbeeldingen toe aan een bestaande vraag
Was dit antwoord nuttig?
3 opmerkingen:
Thank you, I'll check inside. The video is for Clip 3, mine is Go 3
door Deel
@hotdavesweet sorry about that. Use this one instead.
door Deel
Thank u so much
door Deel
Voeg je antwoord toe
hotdavesweet zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 17
Afgelopen 30 dagen: 69
Altijd: 4,231
