Ga door naar hoofdinhoud
De Homelite UT44172 is een snoerloze grastrimmer van 4,8 volt met een oplaadbare batterij en stalen messen. Geproduceerd in 2010 door Homelite. Momenteel uit de handel genomen en vervangen door het model Homelite UT14474.
Were can I get replace battery
Replacement battery's for my cordless grass shear model ut44172
Is dit een goede vraag?
1 Opmerking:
I'm sorry but I can find no one that still carries batteries for this model.
door
Voeg een opmerking toe
1 Antwoord
Filteren op:
Mary Brooks here is the bad news. Looks like this battery is no longer available. Good news is that this is iFixit. You know you can build a replacement by yourself. It is not as complicated or dangerous as you may thing. Take a couple of good pictures and post those with your question. It looks like you open it up the same way as on here Homelite UT44172 Mesbladen vervangen Again, take pictures if unsure. the black tubular thing is actually the battery. The black cover is just that, a plastic cover. Remove the battery by most likely unsoldering the wires. Ultimately I suggest you do something like this Black and Decker 9074 schroevendraaierbatterij repareren just with the type of “batteries” that are appropriate for outr Homelite. Again, it is not as complicated as it may seem.
I would hate for you to discard these shears just because the corporation (Techtronic Industries who owns Homelite) has stopped supporting this equipment. Our landfills are full of stuff that can be fixed and used for many more years. Let us know which way you are going with that. We are always willing to help you and to save the world and humanity. One device at a time.
REPAIR IS WAR ON ENTROPY
Black and Decker 9074 Type 4 Afbeelding
Handleiding
Moeilijkheid:
Gemiddeld
30 minutes
Homelite UT44172 Mesbladen Afbeelding
Handleiding
Moeilijkheid:
Eenvoudig
10 - 20 minutes
Was dit antwoord nuttig?
Voeg je antwoord toe
Mary Brooks zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 19
Altijd: 847
