Ga door naar hoofdinhoud
Samsung's tenth-generation flagship "phablet," featuring its trademark S Pen stylus. Released August 2019.
56 Vragen Bekijk alle
phone left in puddle of water overnight
i went camping and water got into my tent. my phone sat in a small puddle of water for about 5 or so hours while i slept. it wont power on at all, is there anyway to fix this? i have the last remaining photos of a deceased friend on there, i am desperate :(
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
pull your battery IMMEDIATELY. Open up the phone and dry everything. With such important data on it I highly recommend taking it to a phone repair shop to see if they can save it, or at least pull the data from it.
Was dit antwoord nuttig?
Hi @gigigigigi,
Was the phone synced with your Google or Samsung account? If so then perhaps your pictures will also be stored there, and can be accessed from any compatible device, phone or PC etc, as long as you know the account details.
The impurities in the water causes corrosion and provides circuit paths for the electricity which were not in the phone's operating design and could damage the components. The corrosion starts immediately and is ongoing until it is completely cleaned away
First do not try to charge or to turn on your phone and then remove the battery as soon as possible from the phone to minimize any further damage.
Then you need to dis-assemble the rest of the phone and clean all the affected parts using Isopropyl Alcohol 99%+ (available at electronics parts stores) to remove all traces of corrosion and water. If possible do not use "rubbing alcohol" as in some cases this is only 70% IPA or less, can contain additives and is not as effective. If you do have to use it check the label to verify the amount of IPA. The higher the percentage of IPA the better
Here is a link that describes the process. Electronics Water Damage
As always with electronics, especially surface mounted pcb be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board. If possible remove the shields that may be covering some components as the water may have got in there. The ends of any flex cables and their connectors need to be cleaned as well
Hopefully after you have done all this the phone might possibly work correctly again.
Here is a link to the ifixit Galaxy Note10+ guide(s) for repairing your phone, which may help.
If this process seems too daunting, take your phone to a reputable, professional phone repair service, experienced in liquid damage repair and ask for a quote for a repair. If you decide to do this, do it sooner than later.
Voeg je antwoord toe
gigigig ig zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 16
Altijd: 77
