Ga door naar hoofdinhoud
De Vizio e480i-televisie is een 48-inch televisie geproduceerd door Vizio, Inc., opgericht in 2002 in Californië. De Vizio e480i wordt geclassificeerd als een smart-tv en kan worden geïdentificeerd aan de hand van het modelnummer E480i-B2.
Are power supplies interchangeable?
MODEL NUMBER p702ui-b3
It wont turn on. No lights sounds anything. So we are 90% sure it is the power supply especially after looking inside. I have seen some places say you can interchange certain ones but I'm not sure how to figure that out? The power supply in the TV currently is out everything or astronically too expensive. So I'm hoping to find a different one I could use instead. Any help with how to figure out which ones would work?
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
Generally, most PSUs are very specific to the device. Some TVs have the same unit in a series with different screen sizes or functionality, but then it is the same board so the price is the same. Finding a different, cheaper PSU is mostly not possible. What you might do is to open it up and carefully inspect the capacitors of bulging units. Any convex top is an indication of a failed or failing cap. Those can be individually replaced at a far cheaper rate.
Was dit antwoord nuttig?
Score 1
You can interchange the power supplies but there's a few things you'll need to check first. The output voltage cannot be more than three volts higher than the original, the polarity on the device side must be the same, and the plug on the device must be the same size.
Voeg je antwoord toe
daisha jones zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 5
Altijd: 755
